[OpenLayers-Dev] Exception in
OpenLayers.Layer.Grid.removeBackBuffer
Eric Lemoine
eric.lemoine at camptocamp.com
Wed Mar 14 01:39:12 EDT 2012
On Wednesday, March 14, 2012, Tim-Hinnerk Heuer <th.heuer at gmail.com> wrote:
> Hi Eric,
> I couldn't reproduce the problem in any simple example.
Do you still see the exception if you remove the print window in your
application?
Is the layer triggering the bug in the main map or in the print window's
map?
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120314/b5c010e7/attachment.html
More information about the Dev
