[OpenLayers-Dev] getVisibility() gets true if the layer is
invisible by maxResolution
Eric Lemoine
eric.lemoine at camptocamp.com
Tue May 15 14:13:48 EDT 2012
On Tuesday, May 15, 2012, neffets wrote:
> I work with Openlayers 2.11.
> Here a Example:
> lyr = new OpenLayers.Layer.Vector("test", {
> version: "1.1.0",
> strategies: [new OpenLayers.Strategy.BBOX(), oSaveStrategyVG],
> projection: new OpenLayers.Projection("EPSG:4326"),
> maxResolution: 20,
> eventListeners: {
> "visibilitychanged": function() {
> alert("visibility changed");
> In a Map Resolution over 20 the layer is invisible in the map, that's
> right.
The layer is out of range, not invisible. For a layer to be actually
displayed on the map it must be both visible and in range.
> But if I try lyr.getVisibility() I get 'true' in my option it must be
> 'false'.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120515/73c4ca16/attachment.html
More information about the Dev
