[OpenLayers-Dev] getVisibility() gets true if the layer is invisible by maxResolution
neffets martsystems at gmx.net
Tue May 15 13:29:45 EDT 2012
I work with Openlayers 2.11.
Here a Example:
lyr = new OpenLayers.Layer.Vector("test", {
   version: "1.1.0",
   strategies: [new OpenLayers.Strategy.BBOX(), oSaveStrategyVG],
   projection: new OpenLayers.Projection("EPSG:4326"),
   maxResolution: 20,
   eventListeners: {
      "visibilitychanged": function() {
        alert("visibility changed");
In a Map Resolution over 20 the layer is invisible in the map, that's right.
But if I try lyr.getVisibility() I get 'true' in my option it must be
'false'.
On this reason the visibilitychanged event is not fired.
View this message in context: http://osgeo-org.1560.n6.nabble.com/getVisibility-gets-true-if-the-layer-is-invisible-by-maxResolution-tp4974825.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
