[OpenLayers-Dev] Re: ANNOUNCEMENT: OpenLayers 2.12 RC4!
Eric Lemoine eric.lemoine at camptocamp.com
Thu May 17 08:42:37 EDT 2012
On Thursday, May 17, 2012, Roald de Wit wrote:
> Hi Eric,
> On 17/05/12 21:46, Eric Lemoine wrote:
>> We did notice your bug report. Thank you for the very good test case! I
>> could easily reproduce the issue using the example you've provided. Andreas
>> and I talked about the issue. Just like you we think this is a bug in FF
>> that triggers because of the percentage-based tile positioning. Our feeling
>> is that it would be hard to fix it in OpenLayers, if at all possible.
>> That's just a feeling, I agree that it would be worth investigating more. I
>> also think we should try to reproduce the issue outside OpenLayers, and
>> report the bug to the FF team. I'll try to investigate more, and will
>> welcome help with that.
> Thanks to you and Andreas for having looked into the issue. I had no big
> expectations that this problem could be solved easily, but you never know.
> A workaround for the Chrome bug has been found by jorix for example ([1])!
Yeah, I'm sure jorix can fix this issue as well :-)
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120517/8cd8daf0/attachment.html
More information about the Dev mailing list
