[OpenLayers-Dev] Re: ANNOUNCEMENT: OpenLayers 2.12 RC4!
Roald de Wit list at rdewit.net
Thu May 17 08:38:58 EDT 2012
Hi Eric,
On 17/05/12 21:46, Eric Lemoine wrote:
> We did notice your bug report. Thank you for the very good test case!
> I could easily reproduce the issue using the example you've provided.
> Andreas and I talked about the issue. Just like you we think this is a
> bug in FF that triggers because of the percentage-based tile
> positioning. Our feeling is that it would be hard to fix it in
> OpenLayers, if at all possible. That's just a feeling, I agree that it
> would be worth investigating more. I also think we should try to
> reproduce the issue outside OpenLayers, and report the bug to the FF
> team. I'll try to investigate more, and will welcome help with that.
Thanks to you and Andreas for having looked into the issue. I had no big
expectations that this problem could be solved easily, but you never
know. A workaround for the Chrome bug has been found by jorix for
example ([1])! :-)
There is already a bug report for a very similar Firefox bug: [2] which
has a link to a CSS transform scale test page [3]. This page inspired my
to create a similar test case for OL btw. I have just added a comment to
this bug, but I'm aware that this bug is nearly 3 years old already and
may not be solved any time soon.
Regards, Roald
[1] https://github.com/openlayers/openlayers/issues/392
[2] https://bugzilla.mozilla.org/show_bug.cgi?id=504071
[3] http://www.maryanovsky.com/sasha/scaletest/
More information about the Dev mailing list
