[OpenLayers-Dev] [Polygon Rendering] Inverse fill
Andreas Hocevar
ahocevar at opengeo.org
Sat May 19 11:03:27 EDT 2012
Yeah, this issue has probably to do with the geometry clipping that is
done for geometries that span over a long coordinate range, to avoid
running out of coordinate space. A workaround would be to split your
geometries into smaller ones, or use the Canvas renderer as Eric
suggested.
Andreas.
On Sat, May 19, 2012 at 4:03 PM, RICHARD Didier <didier.richard at ign.fr> wrote:
>> On Sat, May 19, 2012 at 1:08 PM, RICHARD Didier <didier.richard at ign.fr>
>> wrote:
>>> Hi devs,
>>> Based on the kml-layer.html with the following code :
>>> var map = new OpenLayers.Map({
>>> div: "map",
>>> layers: [
>>> new OpenLayers.Layer.WMS(
>>> "WMS", "http://vmap0.tiles.osgeo.org/wms/vmap0",
>>> {layers: "basic"}
>>> new OpenLayers.Layer.Vector("KML", {
>>> strategies: [new OpenLayers.Strategy.Fixed()],
>>> protocol: new OpenLayers.Protocol.HTTP({
>>> url: "polygon.kml",/****** the polygon ******/
>>> format: new OpenLayers.Format.KML({
>>> extractStyles: true,
>>> extractAttributes: true,
>>> maxDepth: 2
>>> numZoomLevels:19,/****** 19 levels to see the bug ******/
>>> center: new OpenLayers.LonLat(4.3560894576721,
>>> 45.084481104508),/****** new center ******/
>>> zoom: 17
>>> At this zoom, the symbology is correct : polygon's inside is filled and
>>> the outside is left blank.
>>> When you zoom to level 18, the polygon's inside is not filled anymore
>>> and
>>> the outside is filled.
>>> Tested with OpenLayers 2.11, OpenLayers 2.12-rc4.
>>> The polygon is attached.
>>> I have browse the tickets on trac, but found nothing relevant.
>>> Previously,
>>> there was a hole in the polygon, but it has been removed.
>> Nasty. Do you know an OpenLayers version with which your example
>> works? Your example works correctly with the Canvas renderer
>> (renderers: ['Canvas'] in the layer config), so this is probably a bug
>> in the SVG renderer.
> 2.10, 2.9.1, 2.8, 2.7 : broken
> 2.6 : when zooming in, the KML is not drawn ...
> 2.5 : the browser's support for rendering is broken (despite :
> renderes:['SVG'] added in the code)
> (tested under FF 12 / Linux)
> So, I guess it is an old issue with vector rendering ?!
> didier
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
> RICHARD Didier - Chef du pôle technique du Géoportail
> 2/4, avenue Pasteur - 94165 Saint Mandé Cedex
> Tél : +33 (0) 1 43 98 83 23
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
