[OpenLayers-Dev] [Polygon Rendering] Inverse fill
RICHARD Didier didier.richard at ign.fr
Sat May 19 11:36:33 EDT 2012
> Yeah, this issue has probably to do with the geometry clipping that is
> done for geometries that span over a long coordinate range, to avoid
> running out of coordinate space. A workaround would be to split your
> geometries into smaller ones, or use the Canvas renderer as Eric
> suggested.
We have already splitted the geometry (previously it was a big polygon
with a big hole ;-)
Seems it not enough ... sight !-(
btw, using the Canvas renderer won't work for IE, will it ?
didier
> Andreas.
> On Sat, May 19, 2012 at 4:03 PM, RICHARD Didier <didier.richard at ign.fr>
> wrote:
>>> On Sat, May 19, 2012 at 1:08 PM, RICHARD Didier <didier.richard at ign.fr>
>>> wrote:
>>>> Hi devs,
>>>> Based on the kml-layer.html with the following code :
>>>> var map = new OpenLayers.Map({
>>>>    div: "map",
>>>>    layers: [
>>>>        new OpenLayers.Layer.WMS(
>>>>            "WMS", "http://vmap0.tiles.osgeo.org/wms/vmap0",
>>>>            {layers: "basic"}
>>>>        new OpenLayers.Layer.Vector("KML", {
>>>>            strategies: [new OpenLayers.Strategy.Fixed()],
>>>>            protocol: new OpenLayers.Protocol.HTTP({
>>>>                url: "polygon.kml",/****** the polygon ******/
>>>>                format: new OpenLayers.Format.KML({
>>>>                    extractStyles: true,
>>>>                    extractAttributes: true,
>>>>                    maxDepth: 2
>>>>    numZoomLevels:19,/****** 19 levels to see the bug ******/
>>>>    center: new OpenLayers.LonLat(4.3560894576721,
>>>> 45.084481104508),/****** new center ******/
>>>>    zoom: 17
>>>> At this zoom, the symbology is correct : polygon's inside is filled
>>>> and
>>>> the outside is left blank.
>>>> When you zoom to level 18, the polygon's inside is not filled anymore
>>>> and
>>>> the outside is filled.
>>>> Tested with OpenLayers 2.11, OpenLayers 2.12-rc4.
>>>> The polygon is attached.
>>>> I have browse the tickets on trac, but found nothing relevant.
>>>> Previously,
>>>> there was a hole in the polygon, but it has been removed.
>>> Nasty. Do you know an OpenLayers version with which your example
>>> works? Your example works correctly with the Canvas renderer
>>> (renderers: ['Canvas'] in the layer config), so this is probably a bug
>>> in the SVG renderer.
>> 2.10, 2.9.1, 2.8, 2.7 : broken
>> 2.6 : when zooming in, the KML is not drawn ...
>> 2.5 : the browser's support for rendering is broken (despite :
>> renderes:['SVG'] added in the code)
>> (tested under FF 12 / Linux)
>> So, I guess it is an old issue with vector rendering ?!
>> didier
>>> Eric Lemoine
>>> Camptocamp France SAS
>>> Savoie Technolac, BP 352
>>> 73377 Le Bourget du Lac, Cedex
>>> Tel : 00 33 4 79 44 44 96
>>> Mail : eric.lemoine at camptocamp.com
>>> http://www.camptocamp.com
>> RICHARD Didier - Chef du pôle technique du Géoportail
>> 2/4, avenue Pasteur - 94165 Saint Mandé Cedex
>> Tél : +33 (0) 1 43 98 83 23
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
More information about the Dev mailing list
