[OpenLayers-Dev] [Polygon Rendering] Inverse fill
RICHARD Didier didier.richard at ign.fr
Sat May 19 13:17:27 EDT 2012
> On Saturday, May 19, 2012, RICHARD Didier wrote:
>> > On Saturday, May 19, 2012, Andreas Hocevar wrote:
>> >> On Sat, May 19, 2012 at 5:36 PM, RICHARD Didier
>> >> <didier.richard at ign.fr <javascript:;><javascript:;>>
>> >> wrote:
>> >> > btw, using the Canvas renderer won't work for IE, will it ?
>> >> No, but the VML renderer also shouldn't have this issue.
>> > Right. So to use Canvas in capable browsers and VML in others you'd
>> use
>> > `renderers: ['VML', 'Canvas']` in the layer config.
>> In that case, why not changing :
>>     * Property: renderers
>>     * {Array(String)} List of supported Renderer classes. Add to this
>> list to
>>     * add support for additional renderers. This list is ordered:
>>     * the first renderer which returns true for the  'supported()'
>>     * method will be used, if not defined in the 'renderer' option.
>>    renderers: ['SVG', 'VML', 'Canvas'],
>> into :
>> list to
>>    renderers: ['VML', 'Canvas', 'SVG'],
>> in OpenLayers.Layer.Vector as most of modern browser would support
>> Canvas
>> ? (even if old browser will have to check for the two first before
>> chosing
>> SVG !) Is there a speed issue behind that order of renderers ?
> As far as I know the Canvas renderer re-renders features on each map move.
> This may have performance implications. It also has an impact on user
> experience ? features disappear and reappear.
Ok, so the workaround (VML, Canvas) cannot be considered as a good
solution : better cut the geometry and keep VML, SVG, Canvas order.
didier
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
RICHARD Didier - Chef du pôle technique du Géoportail
2/4, avenue Pasteur - 94165 Saint Mandé Cedex
Tél : +33 (0) 1 43 98 83 23
More information about the Dev mailing list
