[OpenLayers-Dev] [Polygon Rendering] Inverse fill
Eric Lemoine eric.lemoine at camptocamp.com
Sat May 19 13:10:55 EDT 2012
On Saturday, May 19, 2012, RICHARD Didier wrote:
> > On Saturday, May 19, 2012, Andreas Hocevar wrote:
> >> On Sat, May 19, 2012 at 5:36 PM, RICHARD Didier
> >> <didier.richard at ign.fr <javascript:;><javascript:;>>
> >> wrote:
> >> > btw, using the Canvas renderer won't work for IE, will it ?
> >> No, but the VML renderer also shouldn't have this issue.
> > Right. So to use Canvas in capable browsers and VML in others you'd use
> > `renderers: ['VML', 'Canvas']` in the layer config.
> In that case, why not changing :
>     * Property: renderers
>     * {Array(String)} List of supported Renderer classes. Add to this
> list to
>     * add support for additional renderers. This list is ordered:
>     * the first renderer which returns true for the  'supported()'
>     * method will be used, if not defined in the 'renderer' option.
>    renderers: ['SVG', 'VML', 'Canvas'],
> into :
> list to
>    renderers: ['VML', 'Canvas', 'SVG'],
> in OpenLayers.Layer.Vector as most of modern browser would support Canvas
> ? (even if old browser will have to check for the two first before chosing
> SVG !) Is there a speed issue behind that order of renderers ?
As far as I know the Canvas renderer re-renders features on each map move.
This may have performance implications. It also has an impact on user
experience – features disappear and reappear.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120519/edded02c/attachment.html
More information about the Dev mailing list
