[OpenLayers-Dev] 2.11 and Google Maps
Matt Priour mpriour at kestrelcomputer.com
Tue May 22 10:33:56 EDT 2012
2.11.1 sounds like the best option for those that can't / don't wish to
upgrade to 2.12
Matt Priour
OpenGeo
On 5/22/2012 12:27 AM, Eric Lemoine wrote:
> Hi
> Also, as you may know already, 2.11 does not work correctly with the
> current “frozen” (and “release”) version of Google Maps API. The “Map
> Data” popup gets displayed on every map move.
> This means that applications based on 2.11 and using Google layers are
> broken. And there's no known TOS-compliant workaround for this issue.
> This is fixed in the 2.12 and master branches. (Thanks Peter Robins).
> The fix involves changes to one function only of the
> OpenLayers.Layer.Google.v3 mixin.
> So for 2.11 we can tell users to “hot-patch” the mixin in the
> application code. We can also backbort Peter's fix in a 2.11 branch,
> and release 2.11.1. A 2.11.1 release may be easier for people.
> Any opinion?
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com <mailto:eric.lemoine at camptocamp.com>
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2012.0.2176 / Virus Database: 2425/5014 - Release Date: 05/21/12
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120522/64070f62/attachment.html
More information about the Dev mailing list
