[OpenLayers-Dev] 2.11 and Google Maps
Senthil
senthilruban at gmail.com
Tue May 22 02:40:30 EDT 2012
Hi Eric,
It is greatly appreciated as whole openlayers google map based sites are
affected. I made quick hot patch for my site two days back, which was using
2.11-rc1 version. Fix works fine and issue resolved in short time period.
Thanks Peter Robins for quick fix.
Please make patched release for older versions of openlayers which helpful
for many developers who may not able do upgrade openlayers version
immediately.
Regards
Senthil
On Tue, May 22, 2012 at 5:27 PM, Eric Lemoine
<eric.lemoine at camptocamp.com>wrote:
> Hi
> Also, as you may know already, 2.11 does not work correctly with the
> current “frozen” (and “release”) version of Google Maps API. The “Map Data”
> popup gets displayed on every map move.
> This means that applications based on 2.11 and using Google layers are
> broken. And there's no known TOS-compliant workaround for this issue.
> This is fixed in the 2.12 and master branches. (Thanks Peter Robins). The
> fix involves changes to one function only of the OpenLayers.Layer.Google.v3
> mixin.
> So for 2.11 we can tell users to “hot-patch” the mixin in the application
> code. We can also backbort Peter's fix in a 2.11 branch, and release
> 2.11.1. A 2.11.1 release may be easier for people.
> Any opinion?
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120522/6720a029/attachment.html
More information about the Dev
