[OpenLayers-Dev] Github or Trac?
Bart van den Eijnden
bartvde at opengeo.org
Tue May 22 13:44:15 EDT 2012
Hey Phil,
a basic workflow would be forking openlayers under your github account, create a branch, commit, push your changes and create a pull request from there. This will create an issue in the OL github tracker.
If you want to attach a pull request to an existing issue, you need to use something like hub [1]. You cannot attach attachments, I assume you wanted to attach a patch/diff file?
$ git pull-request -i <issue_number> -b openlayers:master -h yourgithubuser:<your_branch>
This assumes "git" is aliased to "hub". Without -i a new pull request/issue is created.
[1] https://github.com/defunkt/hub
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On May 2, 2012, at 11:10 PM, Phil Scadden wrote:
> I reported bug in github but struggled to find a way to attach a file to
> the issue. Does github have all the functionality of trac?
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120522/0510e785/attachment.html
More information about the Dev
