[OpenLayers-Dev] Proj4js updates
Timothy Astle
timothy.astle at caris.com
Mon Sep 10 10:42:22 PDT 2012
Hi Michael,
Is this commit going straight into the trunk? If I recall, most work is
done on the trunk of Proj4js.
The reason that I ask is because we provide Proj4js as part of our
software. I'd like to get a feeling on how this change is being managed
so we can be prepared for the in behaviour. It'd be good to know the
last revision (or have a tagged release) prior to this change.
I do like your proposition. Using AJAX calls for loading definitions
would open doors to using Proj4js. We can then handle cases where an
AJAX call fails to load the definition.
Cheers!
Tim
http://ucode.caris.com/oscar/
On 10/09/2012 2:24 PM, Michael Adair wrote:
> Sorry for crossposting but I suspect there are a lot of Proj4js devs
> on the OL list that aren't on the MetaCRS list and I'd like to get
> their feedback on this as well.
> In any case, as part of getting Proj4js to compile using the Closure
> library in advanced mode, there is some cleanup that I would like to
> do at the same time. I am proposing the following changes:
> 1. remove the dynamic loading of defs: this implies that to use
> Proj4js you would need to have the 'defs' already loaded in your app
> before trying to create the Proj4js.Proj objects. Most app
> frameworks like jQuery support AJAX calls that can be used to load
> defs dynamically if required otherwise, I think apps typically know
> what coordinate systems will be used a priori so they can include the
> required defs statically.
> 2. if the library is no longer asynchronous, I suggest we can remove
> the callbacks passed to the constructor
> 3. the projection code gets included at compile time, so you can pick
> some or all of the projection code in a build config file. (eg. if you
> only need LCC, just include the LCC code in the build). If you don't
> know which projection class you need, you can always build with the
> full code base.
> I've got much of this working now (but not checked in yet) and there
> is some internal changes to the code structure but the external
> interface remains unchanged, ie. you still call Proj4js.transform()
> and the Proj4js.Proj constructors are the same except for removing the
> optional callbacks argument.
> Comments welcome,
> Mike
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Tim Astle
Development Manager
Web Technologies
*CARIS* <http://www.caris.com>
115 Waggoners Lane
Fredericton, New Brunswick
Canada E3B 2L4
Tel: +1.506.458.8533 Fax: +1.506.459.3849
www.caris.com <http://www.caris.com>
*Connect with CARIS*
Twitter <http://www.twitter.com/CARIS_GIS> | LinkedIn
<http://www.linkedin.com/groups?mostPopular=&gid=3217878> | Facebook
<https://www.facebook.com/pages/CARIS-The-Marine-GIS-Experts/123907500987669?v=app_4949752878>
| Google+
<https://plus.google.com/b/114389770462919844434/114389770462919844434/posts>
| YouTube <http://www.youtube.com/user/CARISGIS>
Download your free copy of CARIS Easy View today!
www.caris.com/easyview <http://www.caris.com/easyview>
_________________________________________________________________________
This email and any files transmitted with it are confidential and
intended only for the addressee(s). If you are not the intended
recipient(s) please notify us by email reply. You should not use,
disclose, distribute or copy this communication if received in error.
Any views or opinions expressed in this email are solely those of the
author and do not necessarily represent those of the company. No binding
contract will result from this email until such time as a written
document is signed on behalf of the company.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120910/fcf2f342/attachment.html>
More information about the Dev
