[OpenLayers-Dev] Proj4js updates
Michael Adair
madair at dmsolutions.ca
Mon Sep 10 12:28:34 PDT 2012
Hi Tim,
Yes the changes would go directly into trunk. If you are including this
in other software, it's probably best to use a released version (which
is basically a zipped up SVN repo)
http://trac.osgeo.org/proj4js/wiki/Download
Mike
On 10/09/2012 1:42 PM, Timothy Astle wrote:
> Hi Michael,
> Is this commit going straight into the trunk? If I recall, most work
> is done on the trunk of Proj4js.
> The reason that I ask is because we provide Proj4js as part of our
> software. I'd like to get a feeling on how this change is being
> managed so we can be prepared for the in behaviour. It'd be good to
> know the last revision (or have a tagged release) prior to this change.
> I do like your proposition. Using AJAX calls for loading definitions
> would open doors to using Proj4js. We can then handle cases where an
> AJAX call fails to load the definition.
> Cheers!
> Tim
> http://ucode.caris.com/oscar/
> On 10/09/2012 2:24 PM, Michael Adair wrote:
>> Sorry for crossposting but I suspect there are a lot of Proj4js devs
>> on the OL list that aren't on the MetaCRS list and I'd like to get
>> their feedback on this as well.
>> In any case, as part of getting Proj4js to compile using the Closure
>> library in advanced mode, there is some cleanup that I would like to
>> do at the same time. I am proposing the following changes:
>> 1. remove the dynamic loading of defs: this implies that to use
>> Proj4js you would need to have the 'defs' already loaded in your app
>> before trying to create the Proj4js.Proj objects. Most app
>> frameworks like jQuery support AJAX calls that can be used to load
>> defs dynamically if required otherwise, I think apps typically know
>> what coordinate systems will be used a priori so they can include the
>> required defs statically.
>> 2. if the library is no longer asynchronous, I suggest we can remove
>> the callbacks passed to the constructor
>> 3. the projection code gets included at compile time, so you can pick
>> some or all of the projection code in a build config file. (eg. if
>> you only need LCC, just include the LCC code in the build). If you
>> don't know which projection class you need, you can always build with
>> the full code base.
>> I've got much of this working now (but not checked in yet) and there
>> is some internal changes to the code structure but the external
>> interface remains unchanged, ie. you still call Proj4js.transform()
>> and the Proj4js.Proj constructors are the same except for removing
>> the optional callbacks argument.
>> Comments welcome,
>> Mike
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Tim Astle
> Development Manager
> Web Technologies
> *CARIS* <http://www.caris.com>
> 115 Waggoners Lane
> Fredericton, New Brunswick
> Canada E3B 2L4
> Tel: +1.506.458.8533 Fax: +1.506.459.3849
> www.caris.com <http://www.caris.com>
> *Connect with CARIS*
> Twitter <http://www.twitter.com/CARIS_GIS> | LinkedIn
> <http://www.linkedin.com/groups?mostPopular=&gid=3217878> | Facebook
> <https://www.facebook.com/pages/CARIS-The-Marine-GIS-Experts/123907500987669?v=app_4949752878>
> | Google+
> <https://plus.google.com/b/114389770462919844434/114389770462919844434/posts>
> | YouTube <http://www.youtube.com/user/CARISGIS>
> Download your free copy of CARIS Easy View today!
> www.caris.com/easyview <http://www.caris.com/easyview>
> _________________________________________________________________________
> This email and any files transmitted with it are confidential and
> intended only for the addressee(s). If you are not the intended
> recipient(s) please notify us by email reply. You should not use,
> disclose, distribute or copy this communication if received in error.
> Any views or opinions expressed in this email are solely those of the
> author and do not necessarily represent those of the company. No
> binding contract will result from this email until such time as a
> written document is signed on behalf of the company.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120910/b71f991e/attachment.html>
More information about the Dev
