[OpenLayers-Dev] Problem with rotated points renderer VML (IE <9)
jezaustin
jezaustin at gmail.com
Fri Apr 12 10:26:33 PDT 2013
Was having some trouble with rotating externalGraphics with the VML
renderer. The String "NaN" was winding up in style.rotation, which ruined
the width and height calculations.
A simple amendment to OpenLayers/Renderer/VML.js sorts it out, so I wanted
to share the diff but couldn't be bothered registering with the bug tracker.
So here it is:
Thanks, Jez Austin.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-rotated-points-renderer-VML-IE-9-tp5046463.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
