[OpenLayers-Dev] Problem with rotated points renderer VML (IE <9)
Marc Jansen
jansen at terrestris.de
Mon Apr 15 00:30:15 PDT 2013
Hi Jez,
would you be so kind and turn this into a pull request over at
http://github.com/openlayers/openlayers ?
This way reviewing can happen way easier. Thanks for your work so far,
Marc
On 12.04.2013 19:26, jezaustin wrote:
> Hi,
> Was having some trouble with rotating externalGraphics with the VML
> renderer. The String "NaN" was winding up in style.rotation, which ruined
> the width and height calculations.
> A simple amendment to OpenLayers/Renderer/VML.js sorts it out, so I wanted
> to share the diff but couldn't be bothered registering with the bug tracker.
> So here it is:
> Thanks, Jez Austin.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-rotated-points-renderer-VML-IE-9-tp5046463.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Dipl.-Geogr. Marc Jansen
— Anwendungsentwickler —
terrestris GmbH & Co. KG
Pützchens Chaussee 56
53227 Bonn
Tel: +49 (0)228 / 96 28 99 -53
Fax: +49 (0)228 / 96 28 99 -57
Email: jansen at terrestris.de
Web: http://www.terrestris.de
Amtsgericht Bonn, HRA 6835, Komplementärin: terrestris Verwaltungs-
gesellschaft mbH, vertreten durch: Hinrich Paulsen, Till Adams
More information about the Dev
