[OpenLayers-Dev] OL 2.13 Modify Feature Example IE8/IE7 : Can't remove vertex
HATRI Aurelien aurelien.hatri at atos.net
Tue Aug 13 07:15:37 PDT 2013
Hello,
First of all thanks for the good job you guys are doing on the library.
So my issue is on the modify feature example.
I can't remove a vertex on a Polygon or on a Line with the IE8 and IE7 in 2.13. It worked in 2.12.
I didn't dig very deeply but it seems that now because ModifyFeature doesn't use anymore the DragFeature control after a keydown event OL can't find anymore the vertex feature's id with getFeatureIdFromEvent.
It feels IE 8/7 issue here.
Before I try to push further it will be great if you can find the time to look at it.
Thanks in advance.
Regards.
Ce message et les pi?ces jointes sont confidentiels et r?serv?s ? l'usage exclusif de ses destinataires. Il peut ?galement ?tre prot?g? par le secret professionnel. Si vous recevez ce message par erreur, merci d'en avertir imm?diatement l'exp?diteur et de le d?truire. L'int?grit? du message ne pouvant ?tre assur?e sur Internet, la responsabilit? du groupe Atos ne pourra ?tre engag?e quant au contenu de ce message. Bien que les meilleurs efforts soient faits pour maintenir cette transmission exempte de tout virus, l'exp?diteur ne donne aucune garantie ? cet ?gard et sa responsabilit? ne saurait ?tre engag?e pour tout dommage r?sultant d'un virus transmis.
This e-mail and the documents attached are confidential and intended solely for the addressee; it may also be privileged. If you receive this e-mail in error, please notify the sender immediately and destroy it. As its integrity cannot be secured on the Internet, the Atos group liability cannot be triggered for the message content. Although the sender endeavors to maintain a computer virus-free network, the sender does not warrant that this transmission is virus-free and will not be liable for any damages resulting from any virus transmitted.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130813/67edcc1b/attachment.html>
More information about the Dev mailing list
