[OpenLayers-Dev] OL 2.13 Modify Feature Example IE8/IE7 : Can't remove vertex
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sun Aug 18 12:13:07 PDT 2013
Try
https://github.com/jorix/openlayers/commit/8a30a6b802e03ab61e7ccdfa9fd6b1afcb95deab
HATRI Aurelien wrote
> Hello,
> First of all thanks for the good job you guys are doing on the library.
> So my issue is on the modify feature example.
> I can't remove a vertex on a Polygon or on a Line with the IE8 and IE7 in
> 2.13. It worked in 2.12.
> I didn't dig very deeply but it seems that now because ModifyFeature
> doesn't use anymore the DragFeature control after a keydown event OL can't
> find anymore the vertex feature's id with getFeatureIdFromEvent.
> It feels IE 8/7 issue here.
> Before I try to push further it will be great if you can find the time to
> look at it.
> Thanks in advance.
> Regards.
> ________________________________
> Ce message et les pi?ces jointes sont confidentiels et r?serv?s ? l'usage
> exclusif de ses destinataires. Il peut ?galement ?tre prot?g? par le
> secret professionnel. Si vous recevez ce message par erreur, merci d'en
> avertir imm?diatement l'exp?diteur et de le d?truire. L'int?grit? du
> message ne pouvant ?tre assur?e sur Internet, la responsabilit? du groupe
> Atos ne pourra ?tre engag?e quant au contenu de ce message. Bien que les
> meilleurs efforts soient faits pour maintenir cette transmission exempte
> de tout virus, l'exp?diteur ne donne aucune garantie ? cet ?gard et sa
> responsabilit? ne saurait ?tre engag?e pour tout dommage r?sultant d'un
> virus transmis.
> This e-mail and the documents attached are confidential and intended
> solely for the addressee; it may also be privileged. If you receive this
> e-mail in error, please notify the sender immediately and destroy it. As
> its integrity cannot be secured on the Internet, the Atos group liability
> cannot be triggered for the message content. Although the sender endeavors
> to maintain a computer virus-free network, the sender does not warrant
> that this transmission is virus-free and will not be liable for any
> damages resulting from any virus transmitted.
> Dev mailing list
> Dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1560.x6.nabble.com/OL-2-13-Modify-Feature-Example-IE8-IE7-Can-t-remove-vertex-tp5072314p5073039.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
