[OpenLayers-Dev] OL 2.13 Modify Feature Example IE8/IE7 : Can't remove vertex
Andreas Hocevar ahocevar at opengeo.org
Wed Aug 21 01:25:42 PDT 2013
Great work @jorix - would you mind creating a pull request? I'll review
immediately.
Thanks!
Andreas.
On Sun, Aug 18, 2013 at 9:13 PM, Xavier Mamano (jorix) <
xavier.mamano at gmail.com> wrote:
> Hi,
> Try
> https://github.com/jorix/openlayers/commit/8a30a6b802e03ab61e7ccdfa9fd6b1afcb95deab
> HATRI Aurelien wrote
> > Hello,
> > First of all thanks for the good job you guys are doing on the library.
> > So my issue is on the modify feature example.
> > I can't remove a vertex on a Polygon or on a Line with the IE8 and IE7 in
> > 2.13. It worked in 2.12.
> > I didn't dig very deeply but it seems that now because ModifyFeature
> > doesn't use anymore the DragFeature control after a keydown event OL
> can't
> > find anymore the vertex feature's id with getFeatureIdFromEvent.
> > It feels IE 8/7 issue here.
> > Before I try to push further it will be great if you can find the time to
> > look at it.
> > Thanks in advance.
> > Regards.
> > ________________________________
> > Ce message et les pi?ces jointes sont confidentiels et r?serv?s ? l'usage
> > exclusif de ses destinataires. Il peut ?galement ?tre prot?g? par le
> > secret professionnel. Si vous recevez ce message par erreur, merci d'en
> > avertir imm?diatement l'exp?diteur et de le d?truire. L'int?grit? du
> > message ne pouvant ?tre assur?e sur Internet, la responsabilit? du groupe
> > Atos ne pourra ?tre engag?e quant au contenu de ce message. Bien que les
> > meilleurs efforts soient faits pour maintenir cette transmission exempte
> > de tout virus, l'exp?diteur ne donne aucune garantie ? cet ?gard et sa
> > responsabilit? ne saurait ?tre engag?e pour tout dommage r?sultant d'un
> > virus transmis.
> > This e-mail and the documents attached are confidential and intended
> > solely for the addressee; it may also be privileged. If you receive this
> > e-mail in error, please notify the sender immediately and destroy it. As
> > its integrity cannot be secured on the Internet, the Atos group liability
> > cannot be triggered for the message content. Although the sender
> endeavors
> > to maintain a computer virus-free network, the sender does not warrant
> > that this transmission is virus-free and will not be liable for any
> > damages resulting from any virus transmitted.
> > Dev mailing list
> > Dev at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> http://osgeo-org.1560.x6.nabble.com/OL-2-13-Modify-Feature-Example-IE8-IE7-Can-t-remove-vertex-tp5072314p5073039.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130821/866a24dd/attachment.html>
More information about the Dev mailing list
