[OpenLayers-Dev] Added OSM relation support
Ander Pijoan
ander.pijoan at deusto.es
Tue Feb 26 00:05:59 PST 2013
2013/2/25 Roland Olbricht <roland.olbricht at gmx.de>
> Thank you. This is very useful even if some special cases do not work yet
> perfectly.
> > http://energia.deusto.es/BizkaiSenseIn/
> It works when I check the box "INDICATOR 23". Are there more examples
> inside?
The best layers to see it are inside "INDICADOR 13" turning on
"Edificaciones", you can see the inner polygons being drawn correctly.
Also with "Límite Administrativo" it creates a GeometryCollection with all
the LineStrings from the administrative Boundary (creating a polygon would
need to order them in the right way) or in "INDICADOR 23" inside the
"Accesible" layer, it creates a GeometryCollection with all the LineStrings
from the subway line.
> Where can I find the source code?
The code I have it in
http://energia.deusto.es/BizkaiSenseIn/components/OpenLayers-2.12/OpenLayers.extended.js
which is just the OpenLayers.debug.js file with the "APIMethod read"
extended to parse and draw "relation" tags from the XML.
If its better I could do a diff.
> Best regards,
> Roland
Regards.
Ander Pijoan Lamas
Research Assistant, Deustotech
Computer Science Engineer
University of Deusto
E-mail: ander.pijoan at deusto.es
Phone: +34 664471228
in: http://www.linkedin.com/profile/view?id=162888312
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130226/9da4e05b/attachment.html>
More information about the Dev
