[OpenLayers-Dev] FW: What tools do you use for JS development?
Matt Priour
mpriour at kestrelcomputer.com
Fri Jul 19 11:54:17 PDT 2013
I used to use Eclipse with the Aptana plugin or just the Web Developer
Tools plugin (without Aptana, the 2 don't seem to work well together)
I currently use SublimeText. (sublimetext.com)
I'm seriously considering, though not totally ready to switch to Brackets (
brackets.io)
I've also been helping some people that are using the latest Visual Studio
Web Developer Express and it is better than Aptana or Eclipse at this point
in time if you are windows only and already comfortable with the Visual
Studio IDE.
Matt Priour
Matt Priour
(830) 258-1339
On Mon, Jul 15, 2013 at 4:08 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> Cant really contribute much here as I have pretty much same setup -
> netbeans, java 6/7, (need 6 as critical toolkit arent stable in 7),
> firebug. Most of stuff in ExtJS framework. As might be guessed from that
> setup, backend is tomcat, JSP, with Spring to provide Extdirect.
> Conveniences like code completion a bit more tricky to provide for JS than
> for java, and compiled languages.
> Notice: This email and any attachments are confidential.
> If received in error please destroy and immediately notify us.
> Do not copy or disclose the contents.
> ______________________________**_________________
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/openlayers-**dev<http://lists.osgeo.org/mailman/listinfo/openlayers-dev>
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130719/053316ba/attachment.html>
More information about the Dev
