[OpenLayers-Dev] FW: What tools do you use for JS development?
Benjamin West
bewest at gmail.com
Fri Jul 19 12:53:13 PDT 2013
I'm using docpad:
http://docpad.org/
Makes it easy to standardize a few page layouts with some static data, then
transition towards dynamic server later.
-bewest
On Fri, Jul 19, 2013 at 11:54 AM, Matt Priour
<mpriour at kestrelcomputer.com>wrote:
> I used to use Eclipse with the Aptana plugin or just the Web Developer
> Tools plugin (without Aptana, the 2 don't seem to work well together)
> I currently use SublimeText. (sublimetext.com)
> I'm seriously considering, though not totally ready to switch to Brackets (
> brackets.io)
> I've also been helping some people that are using the latest Visual Studio
> Web Developer Express and it is better than Aptana or Eclipse at this point
> in time if you are windows only and already comfortable with the Visual
> Studio IDE.
> Matt Priour
> Matt Priour
> (830) 258-1339
> On Mon, Jul 15, 2013 at 4:08 PM, Phil Scadden <p.scadden at gns.cri.nz>wrote:
>> Cant really contribute much here as I have pretty much same setup -
>> netbeans, java 6/7, (need 6 as critical toolkit arent stable in 7),
>> firebug. Most of stuff in ExtJS framework. As might be guessed from that
>> setup, backend is tomcat, JSP, with Spring to provide Extdirect.
>> Conveniences like code completion a bit more tricky to provide for JS
>> than for java, and compiled languages.
>> Notice: This email and any attachments are confidential.
>> If received in error please destroy and immediately notify us.
>> Do not copy or disclose the contents.
>> ______________________________**_________________
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**dev<http://lists.osgeo.org/mailman/listinfo/openlayers-dev>
> Dev mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130719/09800ac7/attachment.html>
More information about the Dev
