[OpenLayers-Dev] Openlayers 2.12 canvas renderer issue
Ivan Sipka
frkator at gmail.com
Sat Jun 1 07:34:20 PDT 2013
Hello,
this is my scenario: a map with one baselayer and one overlay vector layer
with one point feature in it. I want to obtain the feature DOM node via
document.getElementById<https://developer.mozilla.org/en-US/docs/Web/API/document.getElementById>.
Feature gets drawn on screen in both cases.
If I use canvas renderer the element gets drawn on map but:
1) document.getElementById(feature.geometry.id) returns null
2) DOM tree inspection via chrome debugger shows no elements in canvas
If I use SVG renderer, I can see it in the DOM tree and
document.getElementById(feature.geometry.id) returns it.
Example code:
<!DOCTYPE html>
<html>
<head>
<script src="http://openlayers.org/api/2.12/OpenLayers.js"></script>
<!--<script src="http://openlayers.org/dev/OpenLayers.js
"></script>-->
<script type="text/javascript">
var map,vectors,feature;
function init() {
var x = 659688.852138;
var y = 5710701.2962197;
map = new OpenLayers.Map({
div: "map",
projection: "EPSG:900913",
controls: [
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar()
var renderer =
OpenLayers.Util.getParameters(window.location.href).renderer;
renderer = typeof(renderer) == 'undefined' ? 'Canvas' :
renderer;
vectors = new OpenLayers.Layer.Vector('vectors', {
renderers: [renderer]
feature = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Point(x,y));
map.addLayers([new OpenLayers.Layer.OSM(),vectors]);
map.setCenter(new OpenLayers.LonLat(x,y), 18);
vectors.addFeatures(feature);
var fetched = document.getElementById(feature.geometry.id);
alert('obtaining feature via document.getElementById has '+
(fetched == null ? 'failed':'suceeded'));
</script>
<style>
#map {
width: 600px;
height: 400px;
</style>
</head>
<body onload="init();">
<div id="map"></div>
</body>
</html>
Default renderer is Canvas if you want to test it you can give the canvas
implementation as a URL parameter like this:
example.html
example.html?renderer=Canvas
or
example.html?renderer=SVG
Judging by the canvas
example<http://openlayers.org/dev/examples/canvas.html> I'm
doing it right. I tried to alternate OL versions from 2.12 to 2.13dev but
it didn't help.
Why is this happening? Is there any clever workaround?
thanks for your time
linski
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130601/c03b39c3/attachment.html>
More information about the Dev
