[OpenLayers-Dev] Openlayers 2.12 canvas renderer issue
Andreas Hocevar
ahocevar at opengeo.org
Sat Jun 1 08:46:39 PDT 2013
This is expected behavior. Canvas works like a drawing board. Elements
drawn to the canvas do not have a DOM representation. Why don't you use in
your vector layer's features array to see if your feature was fetched?
Andreas.
On Sat, Jun 1, 2013 at 8:34 AM, Ivan Sipka <frkator at gmail.com> wrote:
> Hello,
> this is my scenario: a map with one baselayer and one overlay vector layer
> with one point feature in it. I want to obtain the feature DOM node via
> document.getElementById<https://developer.mozilla.org/en-US/docs/Web/API/document.getElementById>.
> Feature gets drawn on screen in both cases.
> If I use canvas renderer the element gets drawn on map but:
> 1) document.getElementById(feature.geometry.id) returns null
> 2) DOM tree inspection via chrome debugger shows no elements in canvas
> If I use SVG renderer, I can see it in the DOM tree and
> document.getElementById(feature.geometry.id) returns it.
> Example code:
> <!DOCTYPE html>
> <html>
> <head>
> <script src="http://openlayers.org/api/2.12/OpenLayers.js
> "></script>
> <!--<script src="http://openlayers.org/dev/OpenLayers.js
> "></script>-->
> <script type="text/javascript">
> var map,vectors,feature;
> function init() {
> var x = 659688.852138;
> var y = 5710701.2962197;
> map = new OpenLayers.Map({
> div: "map",
> projection: "EPSG:900913",
> controls: [
> new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.PanZoomBar()
> var renderer =
> OpenLayers.Util.getParameters(window.location.href).renderer;
> renderer = typeof(renderer) == 'undefined' ? 'Canvas' :
> renderer;
> vectors = new OpenLayers.Layer.Vector('vectors', {
> renderers: [renderer]
> feature = new OpenLayers.Feature.Vector(new
> OpenLayers.Geometry.Point(x,y));
> map.addLayers([new OpenLayers.Layer.OSM(),vectors]);
> map.setCenter(new OpenLayers.LonLat(x,y), 18);
> vectors.addFeatures(feature);
> var fetched = document.getElementById(feature.geometry.id
> alert('obtaining feature via document.getElementById has
> '+ (fetched == null ? 'failed':'suceeded'));
> </script>
> <style>
> #map {
> width: 600px;
> height: 400px;
> </style>
> </head>
> <body onload="init();">
> <div id="map"></div>
> </body>
> </html>
> Default renderer is Canvas if you want to test it you can give the canvas
> implementation as a URL parameter like this:
> example.html
> example.html?renderer=Canvas
> or
> example.html?renderer=SVG
> Judging by the canvas example<http://openlayers.org/dev/examples/canvas.html> I'm
> doing it right. I tried to alternate OL versions from 2.12 to 2.13dev but
> it didn't help.
> Why is this happening? Is there any clever workaround?
> thanks for your time
> linski
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130601/14b685c5/attachment.html>
More information about the Dev
