[OpenLayers-Dev] Testing
Michael Ryan mr at mry4n.net
Wed May 22 07:34:24 PDT 2013
Thank you Andreas for clearing up that I should assign events like so:
events = map.events
The other part of this is that you have specify that the event you are triggering is a left-click.
By tracing the code you see that you need to set the "which" attribute to 1 in the object passed to triggerEvent(), otherwise onClick in featureclick.js ignores the event.
So, this is what my code should have looked like:
events = map.events;
events.triggerEvent( 'mousedown', {xy: new OpenLayers.Pixel(0,0), which: 1}, map);
events.triggerEvent('mouseup', {xy: new OpenLayers.Pixel(0,0), which: 1}, map);
I'm assuming I can get tests written today. Although, I'm not exactly clear how to submit them. If anyone wants to clue me in to that procedure I'd appreciate it.
-Mike
On May 21, 2013, at 5:21 PM, Michael Ryan <mr at mry4n.net> wrote:
> While I've understood I need to use trigger() somehow, I have been unsuccessful in implementing it.
> I was using test for buttonclick as a reference: https://github.com/openlayers/openlayers/blob/master/tests/Events/buttonclick.html
> I would have assumed that within the context of the featurclick example
> https://github.com/openlayers/openlayers/pull/174/files
> I could have used something like
> events = OpenLayers.Events(map, document.getElementById("map"));
> events.triggerEvent({type: 'mousedown', xy: new OpenLayers.Pixel(0,0)}, map);
> events.triggerEvent({type: 'mouseup', xy: new OpenLayers.Pixel(0,0)}, map);
> But, apparently, that's wrong.
> Am I trying to do something that isn't possible? I'm assuming I'm just implementing it wrong. Any thoughts?
> -Mike
> On May 20, 2013, at 5:04 PM, Michael Ryan <mr at mry4n.net> wrote:
>> I'll answer my question about triggering a buttonclick by saying, it looks like you use trigger() which takes coordinates as an argument as in this test:  https://github.com/drewwells/openlayers/blob/master/tests/Control/Measure.html
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130522/5dcad731/attachment.html>
More information about the Dev mailing list
