[OpenLayers-Dev] Testing
Andreas Hocevar
ahocevar at opengeo.org
Thu May 23 12:26:12 PDT 2013
I think the problem is that your init() function won't be called when the
page is loaded by the test runner. So you'll have to call init() from the
test function (test_onClick12 in the current code).
Andreas.
On Thu, May 23, 2013 at 12:33 PM, Michael Ryan <mr at mry4n.net> wrote:
> Thanks for all the help, Andreas.
> I'm pretty sure I can figure the contrib stuff out.
> At the moment, I'm hitting a wall with why a very simple test works if I
> just run the featureclick.html page, but not when I run the test function:
> https://github.com/m1k3ry4n/openlayers/blob/master/tests/Events/featureclick.html
> When I run the html page the logevt array has length 2. In the test, it's
> length 0. Yet I'm running the exact same code.
> I know this is taking a while and I may be missing the 2.13 deadline, but
> I'll keep plugging away at this til I get it right.
> -Mike
> On May 22, 2013, at 10:02 PM, Andreas Hocevar <ahocevar at opengeo.org>
> wrote:
> Hey Michael,
> you should find all information on how to submit code here:
> http://trac.osgeo.org/openlayers/wiki/HowToContribute. You will want to
> create a pull request, as explained here:
> http://trac.osgeo.org/openlayers/wiki/CreatingPatches.
> I hope this helps.
> Andreas.
> On Wed, May 22, 2013 at 9:34 AM, Michael Ryan <mr at mry4n.net> wrote:
>> Thank you Andreas for clearing up that I should assign events like so:
>> events = map.events
>> The other part of this is that you have specify that the event you are
>> triggering is a left-click.
>> By tracing the code you see that you need to set the "which" attribute to
>> 1 in the object passed to triggerEvent(), otherwise onClick in
>> featureclick.js ignores the event.
>> So, this is what my code should have looked like:
>> events = map.events;
>> events.triggerEvent( 'mousedown', {xy: new OpenLayers.Pixel(0,0), which:
>> 1}, map);
>> events.triggerEvent('mouseup', {xy: new OpenLayers.Pixel(0,0), which: 1},
>> map);
>> I'm assuming I can get tests written today. Although, I'm not exactly
>> clear how to submit them. If anyone wants to clue me in to that procedure
>> I'd appreciate it.
>> -Mike
>> On May 21, 2013, at 5:21 PM, Michael Ryan <mr at mry4n.net> wrote:
>> While I've understood I need to use trigger() somehow, I have been
>> unsuccessful in implementing it.
>> I was using test for buttonclick as a reference:
>> https://github.com/openlayers/openlayers/blob/master/tests/Events/buttonclick.html
>> I would have assumed that within the context of the featurclick example
>> https://github.com/openlayers/openlayers/pull/174/files
>> I could have used something like
>> events = OpenLayers.Events(map, document.getElementById("map"));
>> events.triggerEvent({type: 'mousedown', xy: new OpenLayers.Pixel(0,0)},
>> map); events.triggerEvent({type: 'mouseup', xy: new OpenLayers.Pixel(0,0)},
>> map);
>> But, apparently, that's wrong.
>> Am I trying to do something that isn't possible? I'm assuming I'm just
>> implementing it wrong. Any thoughts?
>> -Mike
>> On May 20, 2013, at 5:04 PM, Michael Ryan <mr at mry4n.net> wrote:
>> I'll answer my question about triggering a buttonclick by saying, it
>> looks like you use trigger() which takes coordinates as an argument as in
>> this test:
>> https://github.com/drewwells/openlayers/blob/master/tests/Control/Measure.html
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
Andreas Hocevar
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130523/8d701ed4/attachment.html>
More information about the Dev
