[OpenLayers-Dev] Car icon and details formated with html instead of plain text - please help me
Przemysław Prokopow
przem at post.pl
Fri Sep 6 06:17:33 PDT 2013
Hi Vladimir,
Thanks a lot for the tips.
Your solution with a Box looks clear and straight forward. I really like it.
I just wounder if a data in the Box will be updated dynamically ie. when car
position and parameters change the data will be updated accordingly.
Thanks & Cheers,
Przemek
Dnia 2013-09-06 13:48 Mikulicic, Vladimir napisał(a):
>Sorry Przmek,
>the link's not working:
>Here is the right one: http://www.br.de/wetter
>(The map is a custom OSM rendered Map with mapnik.... but the Markers are
set with Openlayers)
>Greets
>Vladimir
>________________________________________
>Von: Mikulicic, Vladimir
>Gesendet: Freitag, 6. September 2013 13:38
>An: openlayers-dev at lists.osgeo.org
>Betreff: AW: [OpenLayers-Dev] Car icon and details formated with html
>Hi Przemek,
>this is, in my opinion a big problem of Openlayers. We got the same problem
too. Before we used Bing-Maps API, and there it's normal to create
HTML-Markers.
>I am wondering that in the OL-Community is no need for HTML Markers
....excpecially Markers which could be completly controlled.
>The same increddible problem, in my opinion are the Popups... its horrible
to see, that the popup-background is an background-image that comes from the
OL-API.
>But back to your Problem... we solved that ... like this:
>http://www.netzwolf.info/kartografie/openlayers/htmlmarker.htm
>This is the only Implementation i found, that deals with HTML and u can use
it like Markers.
>Our solution with HTML-Markers is: http://www.br.de/weather (Map with
html Markers)
>Greets
>Vladimir
>Von: openlayers-dev-bounces at lists.osgeo.org
[openlayers-dev-bounces at lists.osgeo.org]" im Auftrag von "Przemysław
Prokopow [przem at post.pl]
>Gesendet: Freitag, 6. September 2013 11:51
>Betreff: [OpenLayers-Dev] Car icon and details formated with html instead
>Hi,
>I use OpenLayers libary in my project to display objects on a map.
>I wounder if anybody will be able to help me with my problem.
>I need to show a car icon with following details:
>- car name (label above a car icon)
>- car icon
>- status bar (one line bar with different color showing a status, eg. red
>bar means alarm, green means car is moving, grey car is parked)
>- car parameters (text with car speed, fuel level, distance and rpm)
>OpenLayers libary let you to display one icon and one plain text.
>There is no way to program in OpenLayers text a status bar and text above
>and below needs to be the same color, and to make vertical space you need
to
>use some characters, eg. dots that looks ugly on the interface.
>I need to modify OpenLayers source code and implement the design as I need.
>Probably the way to change a OpenLayers source code would be to change in
>the proper place JavaScript source, so it would accept HTML instead of only
>plain text. Then use HTML to implement a design.
>Could you please advice me, where in a source code should I look to modify
>the code?
>What do you think about such modification? Is it possible and do you
>foreseeing any problems with it?
>I would greatly appreciate any advice or help from you.
>Przemek
>_______________________________________________
>Dev mailing list
>Dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>Bayerischer Rundfunk; Rundfunkplatz 1; 80335 München
>Telefon: +49 89 590001; E-Mail: info at BR.de; Website: http://www.BR.de
>Dev mailing list
More information about the Dev
