[OpenLayers-Dev] OpenLayers 2.13 floating components resize not working
Sosiński Patryk patryk.sosinski at gmail.com
Sun Jul 20 09:18:54 PDT 2014
That was it. Many thanks!
On Sun, Jul 20, 2014 at 3:34 PM, Marc Jansen <jansen at terrestris.de> wrote:
> Hi.
> Try setting fallThrough to true on the OpenLayers.Map.
> HTH,
> Marc
> On 20. Juli 2014 13:46:42 MESZ, gisit <patryk.sosinski at gmail.com> wrote:
>> In my application i am using ExtJS4. After upgrade from OpenLayers 2.12 to
>> 2.13.1 i noticed that i am unable to resize windows (floating components)
>> that are on top of the map, like the resize action was losing focus. When i
>> drag the window outside map div the resizing works fine. The problem does
>> not exist in 2.12. Also when i set the window to modal, the resize is
>> working properly.
>> What may be causing such behaviour?
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/OpenLayers-2-13-floating-components-resize-not-working-tp5151955.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Marc Jansen, terrestris GmbH & Co. KG
> http://www.terrestris.de/
> Dev mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140720/fdc1103c/attachment.html>
More information about the Dev mailing list
