[OpenLayers-Dev] OpenLayers 2.13 floating components resize not working
Marc Jansen
jansen at terrestris.de
Sun Jul 20 06:34:25 PDT 2014
Hi.
Try setting fallThrough to true on the OpenLayers.Map.
HTH,
Marc
On 20. Juli 2014 13:46:42 MESZ, gisit <patryk.sosinski at gmail.com> wrote:
>In my application i am using ExtJS4. After upgrade from OpenLayers 2.12
>to
>2.13.1 i noticed that i am unable to resize windows (floating
>components)
>that are on top of the map, like the resize action was losing focus.
>When i
>drag the window outside map div the resizing works fine. The problem
>does
>not exist in 2.12. Also when i set the window to modal, the resize is
>working properly.
>What may be causing such behaviour?
>View this message in context:
>http://osgeo-org.1560.x6.nabble.com/OpenLayers-2-13-floating-components-resize-not-working-tp5151955.html
>Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>_______________________________________________
>Dev mailing list
>Dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Marc Jansen, terrestris GmbH & Co. KG
http://www.terrestris.de/
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140720/ad5fd06b/attachment.html>
More information about the Dev
