[OpenLayers-Dev] OpenLayers 2.13 floating components resize not working
gisit
patryk.sosinski at gmail.com
Sun Jul 20 04:46:42 PDT 2014
In my application i am using ExtJS4. After upgrade from OpenLayers 2.12 to
2.13.1 i noticed that i am unable to resize windows (floating components)
that are on top of the map, like the resize action was losing focus. When i
drag the window outside map div the resizing works fine. The problem does
not exist in 2.12. Also when i set the window to modal, the resize is
working properly.
What may be causing such behaviour?
View this message in context: http://osgeo-org.1560.x6.nabble.com/OpenLayers-2-13-floating-components-resize-not-working-tp5151955.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
