[OpenLayers-Dev] ESRI // WCS DescribeCoverage 1.1.0
Christopher Eykamp christopher.eykamp at tudor.lu
Fri May 23 08:19:10 PDT 2014
Hello,
I am getting the attached response from an ArcGIS WCS server, with
request DescribeCoverage and protocol version 1.1.0.  OpenLayers (latest
1.x from GitHub) cannot retrieve the Title or Abstract attributes
because the namespaces referenced in the
OpenLayers.Format.WCSDescribeCoverage.v1_1_0 object conflict with what
is referenced in the document.
Specifically, the OpenLayers namespaces object includes this line:
     ows: "http://www.opengis.net/ows/1.1"
This in turn is used to generate a namespaceAlias lookup, which will
return "ows" when looking up "http://www.opengis.net/ows/1.1". However,
in this case, I need "ows" to be mapped to
"http://www.opengis.net/ows".  If I make that change in the namespaces
definition, tests break.  Unfortunately, given the way the aliases are
defined, I cannot add a second namespace that maps to "ows", which might
fix my problem.
I am unsure how to proceed.  I can't tell if I am encountering a
misbehaving server, or if this is just a limitation of the way
OpenLayers is architected (hard-coded namespaces that can only have one
namespace map to a given alias).  Or have I misunderstood something at a
more fundamental level?
Thanks for your advice!
Chris
<CoverageDescriptions xmlns="http://www.opengis.net/wcs/1.1"
xmlns:ows="http://www.opengis.net/ows"
xmlns:owcs="http://www.opengis.net/wcs/1.1/ows"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:gml="http://www.opengis.net/gml"
xsi:schemaLocation="http://www.opengis.net/wcs/1.1
../wcsDescribeCoverage.xsd http://www.opengis.net/wcs/1.1/ows
../owsDataIdentification.xsd"><CoverageDescription><ows:Title>OSDATA.OS_25K_RASTER_1</ows:Title><ows:Abstract/><Identifier>1</Identifier><Domain><SpatialDomain><ows:BoundingBox
crs="urn:ogc:def:crs:OGC::imageCRS" dimension="2"><ows:LowerCorner>0
0</ows:LowerCorner><ows:UpperCorner>16273
8848</ows:UpperCorner></ows:BoundingBox><ows:BoundingBox
crs="urn:ogc:def:crs:EPSG::4326"><ows:LowerCorner>-2.4975225300277217
57.00034657412791</ows:LowerCorner><ows:UpperCorner>-2.0000237693585987
57.270861907368726</ows:UpperCorner></ows:BoundingBox><GridCRS><GridBaseCRS>urn:ogc:def:crs:EPSG::4326</GridBaseCRS><GridOrigin>-2.4975072449484337
57.27084662228944</GridOrigin><GridOffsets>3.057015857620272e-005
-3.0570158576202496e-005</GridOffsets></GridCRS></SpatialDomain></Domain><Range><Field><Title>Field_1</Title><Abstract>Field_1</Abstract><Identifier>Field_1</Identifier><Definition><owcs:AnyValue/></Definition><NullValue>256</NullValue><NullValue>256</NullValue><NullValue>256</NullValue><owcs:InterpolationMethods><owcs:DefaultMethod>nearest</owcs:DefaultMethod><owcs:OtherMethod>bilinear</owcs:OtherMethod><owcs:OtherMethod>bicubic</owcs:OtherMethod></owcs:InterpolationMethods><Axis
identifier="BAND"><AvailableKeys><Key>1</Key><Key>2</Key><Key>3</Key></AvailableKeys><owcs:DataType>Byte</owcs:DataType></Axis></Field></Range><SupportedCRS>urn:ogc:def:crs:EPSG::4326</SupportedCRS><SupportedCRS>urn:ogc:def:crs:EPSG::4326</SupportedCRS><SupportedFormat>image/GeoTIFF</SupportedFormat><SupportedFormat>image/NITF</SupportedFormat><SupportedFormat>image/HDF</SupportedFormat><SupportedFormat>image/PNG</SupportedFormat></CoverageDescription></CoverageDescriptions>
More information about the Dev mailing list
