[OpenLayers-Dev] ESRI // WCS DescribeCoverage 1.1.0
Timothy Astle timothy.astle at caris.com
Fri May 23 09:25:51 PDT 2014
I believe you've hit an oddity in the WCS schemas.
Look at this one:
http://schemas.opengis.net/wcs/1.1.0/wcsDescribeCoverage.xsd
Now look at this one:
http://schemas.opengis.net/wcs/1.1/wcsDescribeCoverage.xsd
Do you see a difference in the ows namespace?  From what I recall, the
second one is correct. A few years ago I was in a similar situation. I'm
thinking ArcGIS Servermight be generating XML using the wrong schemas.
So I believe OL is correct and the "problem" is with ArcGIS Server,
leading from the OGC schema confusion.  I'd love to know the history
behind it.
Do you have control over the ArcGIS Server instance?  It could be
something you want to bring up with ESRI.
Cheers,
Tim
On 23/05/2014 12:19 PM, Christopher Eykamp wrote:
> Hello,
> I am getting the attached response from an ArcGIS WCS server, with
> request DescribeCoverage and protocol version 1.1.0.  OpenLayers
> (latest 1.x from GitHub) cannot retrieve the Title or Abstract
> attributes because the namespaces referenced in the
> OpenLayers.Format.WCSDescribeCoverage.v1_1_0 object conflict with what
> is referenced in the document.
> Specifically, the OpenLayers namespaces object includes this line:
>     ows: "http://www.opengis.net/ows/1.1"
> This in turn is used to generate a namespaceAlias lookup, which will
> return "ows" when looking up "http://www.opengis.net/ows/1.1".
> However, in this case, I need "ows" to be mapped to
> "http://www.opengis.net/ows".  If I make that change in the namespaces
> definition, tests break. Unfortunately, given the way the aliases are
> defined, I cannot add a second namespace that maps to "ows", which
> might fix my problem.
> I am unsure how to proceed.  I can't tell if I am encountering a
> misbehaving server, or if this is just a limitation of the way
> OpenLayers is architected (hard-coded namespaces that can only have
> one namespace map to a given alias).  Or have I misunderstood
> something at a more fundamental level?
> Thanks for your advice!
> Chris
> <CoverageDescriptions xmlns="http://www.opengis.net/wcs/1.1"
> xmlns:ows="http://www.opengis.net/ows"
> xmlns:owcs="http://www.opengis.net/wcs/1.1/ows"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:gml="http://www.opengis.net/gml"
> xsi:schemaLocation="http://www.opengis.net/wcs/1.1
> ../wcsDescribeCoverage.xsd http://www.opengis.net/wcs/1.1/ows
> ../owsDataIdentification.xsd"><CoverageDescription><ows:Title>OSDATA.OS_25K_RASTER_1</ows:Title><ows:Abstract/><Identifier>1</Identifier><Domain><SpatialDomain><ows:BoundingBox
> crs="urn:ogc:def:crs:OGC::imageCRS" dimension="2"><ows:LowerCorner>0
> 0</ows:LowerCorner><ows:UpperCorner>16273
> 8848</ows:UpperCorner></ows:BoundingBox><ows:BoundingBox
> crs="urn:ogc:def:crs:EPSG::4326"><ows:LowerCorner>-2.4975225300277217
> 57.00034657412791</ows:LowerCorner><ows:UpperCorner>-2.0000237693585987 57.270861907368726</ows:UpperCorner></ows:BoundingBox><GridCRS><GridBaseCRS>urn:ogc:def:crs:EPSG::4326</GridBaseCRS><GridOrigin>-2.4975072449484337
> 57.27084662228944</GridOrigin><GridOffsets>3.057015857620272e-005
> -3.0570158576202496e-005</GridOffsets></GridCRS></SpatialDomain></Domain><Range><Field><Title>Field_1</Title><Abstract>Field_1</Abstract><Identifier>Field_1</Identifier><Definition><owcs:AnyValue/></Definition><NullValue>256</NullValue><NullValue>256</NullValue><NullValue>256</NullValue><owcs:InterpolationMethods><owcs:DefaultMethod>nearest</owcs:DefaultMethod><owcs:OtherMethod>bilinear</owcs:OtherMethod><owcs:OtherMethod>bicubic</owcs:OtherMethod></owcs:InterpolationMethods><Axis
> identifier="BAND"><AvailableKeys><Key>1</Key><Key>2</Key><Key>3</Key></AvailableKeys><owcs:DataType>Byte</owcs:DataType></Axis></Field></Range><SupportedCRS>urn:ogc:def:crs:EPSG::4326</SupportedCRS><SupportedCRS>urn:ogc:def:crs:EPSG::4326</SupportedCRS><SupportedFormat>image/GeoTIFF</SupportedFormat><SupportedFormat>image/NITF</SupportedFormat><SupportedFormat>image/HDF</SupportedFormat><SupportedFormat>image/PNG</SupportedFormat></CoverageDescription></CoverageDescriptions>
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Tim Astle
Development Manager
Web Technologies
*CARIS* <http://www.caris.com>
115 Waggoners Lane
Fredericton, New Brunswick
Canada    E3B 2L4
Tel: +1.506.458.8533     Fax: +1.506.459.3849
www.caris.com
*CARIS 2014*
June 2-5, 2014 | Brest, France | 2-5 juin, 2014
Join us in France at CARIS 2014 as we focus on Developing the Blue
Economy. www.caris.com/caris2014/
Venez nous rejoindre en France pour CARIS 2014 et appuyons ensemble
l'Économie Bleue. www.caris.com/caris2014-fr/
Download your free copy of CARIS Easy View today!
www.caris.com/easyview
_________________________________________________________________________
This email and any files transmitted with it are confidential and
intended only for the addressee(s). If you are not the intended
recipient(s) please notify us by email reply. You should not use,
disclose, distribute or copy this communication if received in error.
Any views or opinions expressed in this email are solely those of the
author and do not necessarily represent those of the company. No binding
contract will result from this email until such time as a written
document is signed on behalf of the company.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140523/929151df/attachment.html>
More information about the Dev mailing list
