[OpenLayers-Dev] HERE license will expire
Christian Mayer
ml-cm at meggsimum.de
Fri Nov 3 00:11:36 PDT 2017
the HERE license, which grants access to the map tiles used in the "HERE
Map Tile API" example [1], will expire on 2017-11-16. The reason seems
to be that there is a very high amount of transactions in the last
months (extraordinary high amount). Unfortunately my contact could not
convince HERE to extend the license.
I suggest to come up with a PR, which removes the example introduced
here [2]. Any opinions / other suggestions?
Cheers
Chris
[1] http://openlayers.org/en/latest/examples/here-maps.html
[2] https://github.com/openlayers/openlayers/pull/5640
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20171103/75298db2/attachment.html>
More information about the Dev
