[OpenLayers-Dev] HERE license will expire
Andreas Hocevar
andreas.hocevar at gmail.com
Fri Nov 3 00:34:50 PDT 2017
Another option would be to ask for a new API key. Maybe someone has
found the key and uses it for their application. But in the end it's
HERE's decision. When they don't want to have their API promoted, we'd
better remove the example.
Andreas.
On Fri, Nov 3, 2017 at 8:11 AM, Christian Mayer <ml-cm at meggsimum.de> wrote:
> Hi,
> the HERE license, which grants access to the map tiles used in the "HERE Map
> Tile API" example [1], will expire on 2017-11-16. The reason seems to be
> that there is a very high amount of transactions in the last months
> (extraordinary high amount). Unfortunately my contact could not convince
> HERE to extend the license.
> I suggest to come up with a PR, which removes the example introduced here
> [2]. Any opinions / other suggestions?
> Cheers
> Chris
> [1] http://openlayers.org/en/latest/examples/here-maps.html
> [2] https://github.com/openlayers/openlayers/pull/5640
> Dev mailing list
> Dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
