[OpenLayers-Dev] HERE license will expire
Christian Mayer ml-cm at meggsimum.de
Fri Nov 3 01:15:37 PDT 2017
that's exactly what I thought, that the API-key is misused.
I just did a last attempt to get a new API-key. I'll inform you once I
get the info.
Cheers
Chris
Am 03.11.2017 um 08:34 schrieb Andreas Hocevar:
> Another option would be to ask for a new API key. Maybe someone has
> found the key and uses it for their application. But in the end it's
> HERE's decision. When they don't want to have their API promoted, we'd
> better remove the example.
> Andreas.
> On Fri, Nov 3, 2017 at 8:11 AM, Christian Mayer <ml-cm at meggsimum.de> wrote:
>> Hi,
>> the HERE license, which grants access to the map tiles used in the "HERE Map
>> Tile API" example [1], will expire on 2017-11-16. The reason seems to be
>> that there is a very high amount of transactions in the last months
>> (extraordinary high amount). Unfortunately my contact could not convince
>> HERE to extend the license.
>> I suggest to come up with a PR, which removes the example introduced here
>> [2]. Any opinions / other suggestions?
>> Cheers
>> Chris
>> [1] http://openlayers.org/en/latest/examples/here-maps.html
>> [2] https://github.com/openlayers/openlayers/pull/5640
>> Dev mailing list
>> Dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20171103/d7f42a74/attachment.html>
More information about the Dev mailing list
