[OpenLayers-Dev] HERE license will expire
Christian Mayer
ml-cm at meggsimum.de
Tue Nov 14 00:21:51 PST 2017
Hi all,
thankfully I received a new API-key from HERE or better said from the
German HERE partner geomer, which is valid 4 more months. Then I will
see, what I can do to extend it.
I created a PR [1], which substitutes the old key by the new one.
Cheers
Chris
[1] https://github.com/openlayers/openlayers/pull/7468
On 03.11.2017 09:15, Christian Mayer wrote:
> Hi,
> that's exactly what I thought, that the API-key is misused.
> I just did a last attempt to get a new API-key. I'll inform you once I
> get the info.
> Cheers
> Chris
> Am 03.11.2017 um 08:34 schrieb Andreas Hocevar:
>> Another option would be to ask for a new API key. Maybe someone has
>> found the key and uses it for their application. But in the end it's
>> HERE's decision. When they don't want to have their API promoted, we'd
>> better remove the example.
>> Andreas.
>> On Fri, Nov 3, 2017 at 8:11 AM, Christian Mayer <ml-cm at meggsimum.de> wrote:
>>> Hi,
>>> the HERE license, which grants access to the map tiles used in the "HERE Map
>>> Tile API" example [1], will expire on 2017-11-16. The reason seems to be
>>> that there is a very high amount of transactions in the last months
>>> (extraordinary high amount). Unfortunately my contact could not convince
>>> HERE to extend the license.
>>> I suggest to come up with a PR, which removes the example introduced here
>>> [2]. Any opinions / other suggestions?
>>> Cheers
>>> Chris
>>> [1] http://openlayers.org/en/latest/examples/here-maps.html
>>> [2] https://github.com/openlayers/openlayers/pull/5640
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20171114/cc3a1387/attachment.html>
More information about the Dev
