[OpenLayers-Trac] [OpenLayers] #2959: instance of Array + GWT + Buttons + IFRAME = BUG in Panel.js
OpenLayers trac-20090302 at openlayers.org
Sun Dec 5 20:13:54 EST 2010
 Reporter:  grigoryevigor                      |       Owner:
     Type:  feature                            |      Status:  new
 Priority:  major                              |   Milestone:  2.11 Release
Component:  Control.Panel                      |     Version:  2.10
 Keywords:  instanceof Array IFRAME GWT Panel  |       State:
 I'm using wrapper with OL API in GWT application. I found problem with
 Array type detection in OL. It just not works for array passed from other
 frame (see: http://javascript.crockford.com/remedial.html).
 As for me the problem resides in Panel.js addControls function
     addControls: function(controls) {
         if (!(controls instanceof Array)) {
             controls = [controls];
         this.controls = this.controls.concat(controls);
 failing to detect type correctly, it wraps array once more to the effect
 of nonsense. I also found 40 places using similar sintax around a project
 code. I'm suggesting to replace instanceof with a typeOf function usage
 from example (see URL above).
Ticket URL: <http://trac.openlayers.org/ticket/2959>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
