[OpenLayers-Trac] Re: [OpenLayers] #2972: Closure Compiler for
OpenLayers 2.x
trac-20090302 at openlayers.org
Wed Dec 8 17:03:14 EST 2010
#2972: Closure Compiler for OpenLayers 2.x
Reporter: jorix | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State: Needs Discussion
Changes (by jorix):
* state: => Needs Discussion
Comment:
To attach the compiler has used some material from Closure Compiler (in
"bulid/") and Closure Library (in "tools/")
The compiler is the only material that is not in the patch. "compiler.jar"
must be downloaded to the folder "tools/closure-compiler/bin/" (without
"compiler.jar" build.py work with jsmin)
NOTE: The patch only uses part of the power of the compiler, to obtain
more benefit requires the use jsDoc tags and Closure Library, but this is
hard work.
Ticket URL: <http://trac.openlayers.org/ticket/2972#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
