[OpenLayers-Trac] Re: [OpenLayers] #2972: Closure Compiler for
OpenLayers 2.x
trac-20090302 at openlayers.org
Fri Dec 10 12:40:08 EST 2010
#2972: Closure Compiler for OpenLayers 2.x
Reporter: jorix | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State: Needs Discussion
Comment(by jorix):
Features proposed in the patch for use of the Closure Compiler:
* Use any OpenLayers configuration (*.cfg)
* Show where there have been compilation errors: source file and line
number (source code is used, not jsmin)
* Maximize the checks but discard massive warnings (9676 warnings
reported using "- warning_level VERBOSE"!)
* Ensure the verification of undeclared variables (distractions make
these variables as global)
* Use externs to declare names of other products, commercial maps,
Proj4js ...
* Use SIMPLE_OPTIMIZATIONS, which compresses the code by 20%
(ADVANCED_OPTIMIZATIONS requires a study of the pros and cons)
* Launch the Java compiler from phython (discard the use of the Service
API. To call the compiler uses material from "Closure Library")
Ticket URL: <http://trac.openlayers.org/ticket/2972#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
