[OpenLayers-Trac] [OpenLayers] #2910: Fix sizing of the Box
handler's box
trac-20090302 at openlayers.org
Tue Nov 2 04:48:43 EDT 2010
#2910: Fix sizing of the Box handler's box
Reporter: ahocevar | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Box | Version: 2.10
Keywords: | State: Review
This should already have been fixed in #1593, which only fixed the issue
visually because the 2 pixel box border and the 1 pixel offset due to the
map border in our examples (fixed with #2247) make it appear correctly
with both the w3c and the traditional box model.
The patch proposed here determines the border width of all box edges
(instead of just the left+right and top+bottom sums), calculates the
correct width and height offsets depending on the box model, and does not
rely on browser detection any more to determine the box model.
Two manual tests are added (tests/manual/box-quirks.html and tests/manual
/box-strict.html), which appear correctly in FF3.6, IE8 and Safari 5. Unit
tests for Handler.Box were missing, so I also created some. All pass in
the mentioned browsers.
Thanks for any review.
Ticket URL: <http://trac.openlayers.org/ticket/2910>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
