[OpenLayers-Trac] [OpenLayers] #2916: suggested patch to OpenLayers.Layer.ArcGIS93Rest.getUrl method
OpenLayers trac-20090302 at openlayers.org
Thu Nov 4 11:45:29 EDT 2010
 Reporter:  giohappy  |       Owner:
     Type:  feature   |      Status:  new
 Priority:  minor     |   Milestone:  2.11 Release
Component:  general   |     Version:  2.10
 Keywords:            |       State:
 I've noticed that the getUrl method in ArcGIS93Rest sets the thw
 params BBOXSR and IMAGESR based on the map projection.
 This is generally ok, but doesn't work if we want to use the "google
 projection" (EPSG:900913). In such case we need to submit a specific
 CSR to ArcGIS service: 102113
 For my needs I've modified the method with the attached patch to check
 if BBOXSR and IMAGESR params have been set as layer options.
 giovanni
Ticket URL: <http://trac.openlayers.org/ticket/2916>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
