[OpenLayers-Trac] [OpenLayers] #2943: Panning problem in IE
OpenLayers trac-20090302 at openlayers.org
Mon Nov 22 12:33:19 EST 2010
 Reporter:  paweluz                |       Owner:
     Type:  bug                    |      Status:  new
 Priority:  minor                  |   Milestone:
Component:  Control.Pan            |     Version:
 Keywords:  panning, pan, IE, map  |       State:
 Problem: When I have a cursor e e.g. at the center of the map, and then do
 a panning to the bottom of of the web browser (the mouse goes out of the
 map viewport - try to "escape" from the map area during the padding to the
 status bar) the map position strangely changes. This stuff happens only in
 the IE
 You can see that in this example:
 http://openlayers.org/dev/examples/fullScreen.html
 My comments on that: When I do the drag (panning on the map) an move e.g.
 on the bottom status bar of the Web Browser the mouseout event fires up.
 Then it calls the method panMapDone but with the '''wrong XY values! '''.
 I did some debug and the values are always less than 0. Here you have got
 the link to an example:
 http://img252.imageshack.us/img252/3498/panningbug.png
 The values are always OK when I do the panning on the map, but when I go
 outside the map there is a problem.
Ticket URL: <http://trac.openlayers.org/ticket/2943>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
