[OpenLayers-Trac] Re: [OpenLayers] #2210: Deactivate controls when
destroying
trac-20090302 at openlayers.org
Thu Oct 14 14:37:55 EDT 2010
#2210: Deactivate controls when destroying
Reporter: ahocevar | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control | Version: 2.8
Keywords: | State: Needs More Work
Comment(by jorix):
Replying to [comment:5 jorix]:
> ... I also tested r10732 + #2210 and the tests ...
is ... I also tested r10834 + #2210 and the tests...
Thus #2210 is not a problem, is the solution solves two problems at once.
Note: Panel.js reqire a manual merge (without applying in panel.js test
also works)
Ticket URL: <http://trac.openlayers.org/ticket/2210#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
