[OpenLayers-Trac] Re: [OpenLayers] #2835: Panel Control: Panel is
displayed after deactivate
trac-20090302 at openlayers.org
Thu Oct 14 18:34:23 EDT 2010
#2835: Panel Control: Panel is displayed after deactivate
Reporter: jorix | Owner:
Type: bug | Status: closed
Priority: minor | Milestone: 2.11 Release
Component: Control.Panel | Version: 2.10
Resolution: fixed | Keywords:
State: Complete |
Comment(by jorix):
Replying to [comment:6 ahocevar]:
> We had to partially revert r10732 with r10834. The deactivate sequence
is still fixed, but the destroy sequence should be fixed as part of #2210.
Here we have crossed several tickets: r10813 changed the test that failed
due to #2850 due to an oversight of mine in #2835 where he said:
var div = panel.div;
panel.destroy();
t.ok(panel.div.innerHTML == "".
had to say:
panel.destroy();
t.ok(div.innerHTML == "",
but r10732 put:
panel.destroy();
t.eq(panel.div, null,
is not the same (this is a test that #2850 is fixed).
But r10790 undo fix #2850, and test changet by r10813 failed.
this looks like a scene from the '''Marx Brothers'''.
#2850, is ok (and test {{{... div.innerHTML == "", ...}}} works with
this.deactivate() in panel destroy, with or without #2850).[[BR]]
The original patch from #2864 and mine working properly with the right
test, but they are different views of the problem (I thought of something
like #2210)[[BR]]
And #2210 is ok.
Uff!
Happy ending? :-))
Ticket URL: <http://trac.openlayers.org/ticket/2835#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
