[OpenLayers-Trac] Re: [OpenLayers] #3228: Double tap on Android
select the map
trac-20090302 at openlayers.org
Sun Apr 3 16:15:52 EDT 2011
#3228: Double tap on Android select the map
Reporter: sbrunner | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Events | Version: 2.10
Keywords: mobile | State: Review
Comment(by sbrunner):
Replying to [comment:7 erilem]:
> Quick comments:
> * we'll also need to update the Click, Drag and Point handlers to
remove the "unregister mouse listeners" code from the touchstart callback
Effectively, I will done it later, than I will done a patch with it !
> * I'd like to see a manual test showing the problem that doesn't use
!OpenLayers at all
Good Idea I will work on it.
> * I feel that we should not commit this for 2.11
OK for me ;-)
CU, Stéphane
Ticket URL: <http://trac.openlayers.org/ticket/3228#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
