[OpenLayers-Trac] Re: [OpenLayers] #3262: OpenLayers Event objects
in Firefox have unstable 'getPreventDefault' methods.
trac-20090302 at openlayers.org
Tue Apr 26 02:57:16 EDT 2011
#3262: OpenLayers Event objects in Firefox have unstable 'getPreventDefault'
methods.
Reporter: mgleahy | Owner:
Type: feature | Status: reopened
Priority: minor | Milestone: 2.12 Release
Component: Handler.Click | Version: 2.10
Resolution: | Keywords:
State: |
Changes (by erilem):
* component: general => Handler.Click
* milestone: 2.11 Release => 2.12 Release
Comment:
Thanks for following up.
In fact the issue is specific to the click handler. The click handler
sends a clone of the event object to the "click" callback. This is because
the click handler runs the "click" callback in a timer callback—at a time
when the actual event object may no longer be valid.
The "click" callback running outside the actual event handling "thread"
makes calling functions like preventDefault not applicable. So I think we
should document (a) that the event object isn't a real one, and (b) what
properties of that object can be read.
"getDefaultProperty" (or "defaultPrevented") could be of one these
properties. But that would not convert this object into a real event
object, so passing it to {{{jQuery.event.fix()}}} or similar would still
be unsafe.
As a last note, people who do need an actual "click" event should not use
the click handler. Instead they should rely on
{{{OpenLayers.Event.observe}}} or other functions from other libs.
I hope it makes sense.
Ticket URL: <http://trac.openlayers.org/ticket/3262#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
