[OpenLayers-Trac] Re: [OpenLayers] #3272: Handler.Path: It is not
possible to draw accurately
trac-20090302 at openlayers.org
Wed Apr 27 16:59:05 EDT 2011
#3272: Handler.Path: It is not possible to draw accurately
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: critical | Milestone: 2.11 Release
Component: Handler.Path | Version: SVN
Keywords: | State: Needs More Work
Comment(by erilem):
Replying to [comment:13 jorix]:
> Replying to [comment:12 erilem]:
> > What do you mean by "near the bottom"? That is strange. I'll try to
get more people to test B0 in Android tomorrow. Thanks a lot jorix.
> Sorry, "near the last point" (automatic translation that I have not
reviewed well, sorry)
Ok. In B0 dblclickTolerance defaults to 20 on touch devices. My goal was
to not add a new point if the user accidentally does two touches at nearly
the same location. But I'm now starting to think this isn't necessary (and
wanted), and that the dblclickTolerance should only be checked when within
the timer, for the feature finalization (as done in A0). I'll try to come
up with a C0 patch that takes the best from A0 and B0.
Ticket URL: <http://trac.openlayers.org/ticket/3272#comment:14>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
