[OpenLayers-Trac] [OpenLayers] #3451: Rendering fails on setting
minScale on Vector
Layer with different Projection and Units as in the Map
trac-20090302 at openlayers.org
Fri Aug 5 10:53:45 EDT 2011
#3451: Rendering fails on setting minScale on Vector Layer with different
Reporter: mca | Owner: euzuro
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Layer | Version: 2.10
Keywords: Rendering, MinScale, MaxScale | State:
I tried to upgrade from 2.9.1 to 2.10 and wondered where my WFS Features
were gone.
Often you have a map with 900913 and a WFS Layer in 4326 which is
requested in 4326 and automatically transformed to 900913 in the client.
So far so good.
I figures out that in OpenLayers.Layer.initResolutions() the resolutions
are derived from minScale or maxScale if other properties aren't set:
Line 946:
if(this.options.minScale) {
maxResolution = OpenLayers.Util.getResolutionFromScale(
this.options.minScale, this.units);
this calculation is based on this.units which is degree for the layer.
Later these resolutions are compared with the map.resolution in the
calculateInRange() Method which fails as we compare meters per pixel with
degrees per pixel.
A possible fix would be a change on initResolutions as follows
(this.map.units instead of this.units):
this.options.minScale, this.map.units);
This should also be applied to the calculateResolutions-Method.
It is the same in 2.11-rc1.
Ticket URL: <http://trac.openlayers.org/ticket/3451>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
