[OpenLayers-Trac] Re: [OpenLayers] #3451: Rendering fails on
setting minScale on
Vector Layer with different Projection and Units as in the Map
trac-20090302 at openlayers.org
Mon Aug 8 03:27:45 EDT 2011
#3451: Rendering fails on setting minScale on Vector Layer with different
Reporter: mca | Owner: euzuro
Type: bug | Status: new
Priority: major | Milestone: 2.12 Release
Component: Layer | Version: 2.10
Keywords: Rendering, MinScale, MaxScale | State:
Changes (by erilem):
* milestone: 2.11 Release => 2.12 Release
Comment:
This indeed sounds like a bug in the library.
Using {{{this.map.units}}} for the calculation of {{{maxResolution}}}
isn't correct, because {{{this.map.units}}} is just a default
configuration value. Using {{{this.map.getUnits()}}}, to get the units of
the base layer, would be better, but it won't work if the map doesn't have
a base layer yet. Using {{{this.map.getUnits() || this.map.units}}} might
be a good enough solution. I'm still wondering whether we should use
{{{this.map.getUnits() || this.map.units}}} for every call to
{{{getScaleFromResolution}}} and {{{getResolutionFromScale}}} done in
Layer.js.
Setting Milestone to 2.12 as this isn't a regression from 2.10.
Ticket URL: <http://trac.openlayers.org/ticket/3451#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
