[OpenLayers-Trac] Re: [OpenLayers] #3419: Tile simplifications and partial rewrite
OpenLayers trac-20090302 at openlayers.org
Wed Aug 10 05:48:57 EDT 2011
 Reporter:  ahocevar  |       Owner:  ahocevar
     Type:  feature   |      Status:  new
 Priority:  minor     |   Milestone:  2.12 Release
Component:  Tile      |     Version:  2.10
 Keywords:            |       State:  Review
Comment(by ahocevar):
 Thanks a lot for the review Eric.  I agree with your suggestions, so if
 you could create a new patch that would be great. Just one note: I had
 changed imgDiv to image already in one of the #3061 patches, but decided
 to not do it in #3419. Even if it's not an API property, people may be
 relying on it, and we use it in hundreds of test assertions as well. But I
 won't object if you want to make this change. Also I seem to remember that
 I had something like (singleTile & 1) | ((indexOf() !- -1) & 2) in a
 previous iterations and it did not work as expected. But if you can add
 test cases that would be great.
 Regarding the image loading icons: I saw them in FF5 as well and did not
 find a way to get rid of them so far. I'd say I'll wait for your updated
 patch, and then give this another look.
 Also, now that r12185 was reverted, we need to set the initial opacity
 when creating a tile. I can add this after your new patch as well.
Ticket URL: <http://trac.openlayers.org/ticket/3419#comment:21>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
